MinIO — Deployment Template
MinIO App Template
This App Template deploys a fully configured MinIO instance inside an LXC container managed by the PUQcloud Proxmox Module.
The application runs in full isolation, ensuring security, consistent performance, and separation for each user.
Each deployment is unique: PUQcloud automatically generates admin credentials, sets environment variables, creates required directories, mounts storage paths, and starts a fully functional MinIO instance without any manual steps.
Key Features
  • Runs inside an isolated LXC container (Proxmox)
  • Standalone binary-based MinIO installation
  • Auto-generated admin credentials
  • Web-based management console
  • User-specific storage directories (volumes)
  • Built-in startup validation
  • No manual configuration needed
Dynamic Environment Variables
  • MINIO_ROOT_USER – admin username
  • MINIO_ROOT_PASSWORD – admin password
  • MINIO_VOLUMES – mounted storage path for MinIO data
  • MINIO_BROWSER_REDIRECT_URL – web console URL
How it works
  1. PUQcloud Panel creates an LXC container via the Proxmox Module
  2. The template applies all required environment variables
  3. Storage paths are mounted into the container
  4. MinIO binary is downloaded and installed
  5. Systemd service is created and started automatically
  6. The MinIO instance is ready to use with its web console
This template allows any user to deploy MinIO in minutes — secure, isolated, and fully managed by PUQcloud.
MinIO-binary-fa146af8-5d0e-4e18-867f-6ce11a3be00b.json (7.3 KB)
