Vaultwarden App Template
This App Template deploys a fully configured Vaultwarden instance inside an LXC container managed by the PUQcloud Proxmox Module.
The application runs in full isolation using Docker, ensuring security, consistent performance, and separation for every user.
Each deployment is unique: PUQcloud automatically generates admin tokens, sets environment variables, mounts storage paths, and builds a fully functional Vaultwarden instance without any manual steps.
Key Features
- Runs inside an isolated LXC container (Proxmox)
- Full Docker-based Vaultwarden installation
- Auto-generated admin token
- Automatic reverse-proxy configuration (Nginx)
- User-specific data directory (
data) - Built-in health check and startup validation
- No manual configuration needed
Dynamic Environment Variables
DATA_PATH– mounted storage for Vaultwarden dataADMIN_TOKEN– admin token for management accessWEBSOCKET_ENABLED– enable WebSocket supportSIGNUPS_ALLOWED– control if user signups are allowedDOMAIN– main URL of your Vaultwarden instancePUSH_RELAY_URI– WebSocket relay URL
How it works
- PUQcloud Panel creates an LXC container via the Proxmox Module
- The template applies all required environment variables
- Storage paths are mounted into the container
- Docker Compose automatically deploys Vaultwarden
- Nginx reverse proxy is configured with the correct domain
- The Vaultwarden instance is ready to use
This template allows any user to deploy Vaultwarden in minutes — secure, isolated, and fully managed by PUQcloud.
Vaultwarden-docker-216d7353-2520-484b-81d0-e46b1dfc9a60.json (7.2 KB)
